Laser cut Box
A project log for VFD NTP Clock
I wanted a "never set" clock, so I made one using a VFD and Ethernet NTP.
pyroferPyrofer 07/30/2014 at 10:400 Comments
The box for the clock was designed with Inkscape and uploaded to Razorlab.co.uk. The finished parts posted back it was simply a matter of gluing them together.
Unlike a lot of laser cut boxes I didn't use interlocking tabs as I don't like the look they give the finished box. Normal wood glue on the edges forms a good enough bond to hold the whole thing together.
