So far I have communication with the SI4320 through SPI, still haven't managed to listen in on the transmitter.
Pin Out is as follows:
SI4320-------------------------------------------Arduino
1 (SDI) ---------------------------------------------- D11
2 (SCK) -------------------------------------------- D13
3 (nSEL) ------------------------------------------- D10
4 (SDO) ------------------------------------------- D12
6 (floating input when using FIFO)-------- D8 (used to tie it down)
11 (VSS) ------------------------------------------- Ground
14 (VDD) ----------------------------------------- +5vdc (2.2-5.4VDC)
