Uploaded PCB layout
A project log for Visually Impaired Pulse Echo Ranging (VIPER)
A technology for helping those whose vision is impaired to more easily navigate through their local environments
r-snyderR. Snyder 10/09/2016 at 19:120 Comments
Note: The piezoelectric transducer pads, power switch pads, and battery pads are laid out as if those components are to be mounted on the printed circuit board (PCB), but those components can (and at least in the case of the transducers should) be separated from the PCB by wires.
