Schematic
A project log for Ghosty, the Thinking Nightlight
When you go to the bathroom this light (very subtle) comes on--10 seconds after you leave, it turns off. Sleep well, move around safely.
mike-rigsbyMike Rigsby 09/30/2016 at 14:090 Comments
Here's the diagram showing the way parts are assembled:
This is the led--note that I have shrink wrapped all exposed conductive surfaces.
This photo shows the Ping transducer, photocell and 30K (approximate) resistor.
Note that the Ping transducer has only three pins--many similar devices have four pins and that impacts the circuit connections and software.
