600Wh Battery Box
600Wh portable battery made of 18650 cells with an included 1000W inverter
Public Chat
This battery box can store up to 600Wh of energy and features an inverter to convert the 12V DC from the battery to 220v AC to power home appliances. It also features a USB port on the side for charging a phone and a wireless charger on the top of the case. The battery is made of 90 18650 cells salvaged from broken laptop batteries. Since not all the cells have the same capacity, the packs need to be balanced. I'm using a 3S BMS for this task. The battery can be recharged using an off the shelf LiPo charger.
battery_sch.pdf
Schematic of the system
Adobe Portable Document Format - 54.80 kB - 04/24/2018 at 18:40
Preview
Pack Holder.stl
3D printed pack holder Holds a single battery pack to the case
Standard Tesselated Geometry - 30.16 kB - 04/24/2018 at 18:38
Download
  • 90 × 18650 cells Salvaged from broken laptop batteries
  • 1 × 12V 1000W Modified Sine Wave Inverter https://www.ebay.ch/itm/Spannungswandler-12V-1000W-6000W-Stromwandler-Solar-Inverter-Wechselrichter/371674435401?hash=item568985cf49:m:moVKN3p_tJR6n9R7ZrMxSnw
  • 1 × 3S 150A BMS
  • 1 × 12V LED Push Button https://www.ebay.ch/itm/142264596040?ViewItem=&item=142264596040&var=441322709257
  • 1 × 12V 70A Relay https://www.ebay.ch/itm/131106074235?ViewItem=&item=131106074235
View all 8 components
Ahron Wayne wrote 01/08/2021 at 04:17 point
Do you still use this? Nice box!
Diego V wrote 01/11/2021 at 10:15 point
Thanks! I haven't used it for a while but it still works fine.
I might need to check the batteries before putting it under load again.
