Hackaday.io Hackaday.io
Sign up Log in
Toenail Springs
Ingrown toenails are no fun
oneohmoneohm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
  • The 2016 Hackaday Prize
View Gallery
429
0
0
0
Team (1)
  • oneohmoneohm
Join this project's team
ongoing project
2016HackadayPrize
This project is submitted for
  • Assistive Technologies
This project was created on 10/02/2016 and last updated 10 years ago.
Description
How about an assistive technical fix for the common problem of ingrown toenails. Toenail Springs - -Small spring steel strips of differing strength -Unobtrusive, flat profile -Etched hole pattern ensures good adhesion -Flexible superglue with disappearing dye for easy application -Superglue accelerator pads pre-attached to the spring clips -Removable with acetone nail polish remover The idea is to relieve tension on the nail and gently reshape to a flatter profile.
Project Logs
Collapse
  • Preparing bond accelerator pads
    oneohm • 10/02/2016 at 22:44 • 0 comments
    The idea here is to pre-treat some small fabric/microfiber pads with something that will trigger the glue to cure instantly. I tried some Zip-Kicker, but the results were underwhelming - perhaps the active ingredient evaporated? There are other - even reasonably non-toxic substances that will rapidly cure cyanoacrylates. Baking soda seems to be the best option. Next time I will try to work some baking soda into the pads.
  • Joined spring assembly
    oneohm • 10/02/2016 at 22:37 • 0 comments
    A special flexible superglue (octyl/butyl cyanoacrylate blend) allows for a slightly flexible bond preventing the spring from breaking apart as the nail naturally flexes.
    https://www.amazon.com/Abbott-Laboratories-GLUture-Topical-Adhesive/dp/B00IJVQVO6
  • Trimmed and Ready to Join
    oneohm • 10/02/2016 at 22:31 • 0 comments
    Rounded corners might be nice - perhaps in the next revision...
  • Rough cut spring strips
    oneohm • 10/02/2016 at 22:29 • 0 comments
    Here are the rough cut spring segments - with similar width.
  • Preparing the springs
    oneohm • 10/02/2016 at 22:24 • 0 comments
    Starting with a sheet of etched screen mesh from E-Fab http://www.efabsales.com/screen-mesh/ I cut some small strips of different widths that included the border. I then trimmed these and glued them together with the border overlapping. The mesh acting as small attachment points on either end.
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
No more stuff rolling around the trunk with this custom insert.
Project Owner Contributor
Tesla Model S trunk insert with net
daviddavid
yay, grafitty
multi stencil experiment
rawerawe
A small table top tool tidying system
TTTTT - Tiny Table Top Tool Toter
concretedogconcretedog
An upper body model for making wearable technology items, articulated with skeletal approximations
Articulated torso with arms
kenji-larsenKenji Larsen
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Toenail Springs", please tell us the reason.
Send message
Remove Member
