Isolation Board
A project log for Universal Power Supply
Convert whatever power source is available to the one you need
oneohmoneohm • 10/03/2016 at 02:55•0 Comments
Here are a few of the components that ended up on the isolation board:
Close to the current configuration (not to worry - specifics are on the way)
The bottom:
Bottom with protective sheet in place:
