A look under the isolation transformer
A project log for Universal Power Supply
Convert whatever power source is available to the one you need
oneohmoneohm • 10/10/2016 at 04:11•0 Comments
A look under the isolation transformer.
The wire routing has changed since this was taken, but this shows the layout of the components that are normally obscured by the transformer.
