Heart Surgery
A project log for Universal Power Supply
Convert whatever power source is available to the one you need
oneohmoneohm 10/04/2016 at 23:340 Comments
To monitor the current I modified the boards to accept some Allegro high current sensor ICs.
http://www.allegromicro.com/en/Products/Current-Sensor-ICs/Fifty-To-Two-Hundred-Amp-Integrated-Conductor-Sensor-ICs.aspx
The board has a hefty jumper connection (JM1) to monitor current to ground, but I also wanted to to measure output current (for some experiments these will not be the same).
This turned out to be more difficult that just cutting a trace as power was also being routed on some of the internal layers. Two carefully drilled holes and a slot cut through the board. These were later insulated with some clear acrylic sealant (nail polish).
Another angle:
I carefully removed the solder mask to create a footprint for the second current sensor:
Here you can see them mounted to the module on the right:
