Designing iURIS
A project log for iURIS - Being Independent
Our project is a spectacle mountable device which helps under neck disabled people to control mobile and computers.
nagariajheelnagariajheel 10/03/2016 at 13:250 Comments
After everything was finalized, many designs were thought for iURIS and implemented. 3D files for iURIS were designed using Autodesk. They were 3D printed and assembled. Casing for each component was carefully designed keeping in mind the user's comfort. Also the Li-ion Battery was chosen due to its consistency and better life. The 3D printed product is uploaded.
