How much SiO2 to desiccate a spool?
A project log for Filament storage science
Beware. Plastic containers are moisture permeable.
DeepSOICDeepSOIC 10/04/2016 at 20:310 Comments
Now that I have determined the specs of silica gel, time to apply.
Let's dry a saturated 1kg spool of ABS. ABS water absorption is 0.2-0.4%, as I found from internet.
http://stephen-webster.co.uk/wp-content/uploads/2011/02/Thermoforming-materials-storage-and-drying-Athlone.pdf
-> 1kg spool can hold up to 4 g of water. So, I need no less than 27 g of cat litter to dry out one spool. Or 19 g of proper silica gel desiccant.
