Xelopics E.C.A.M.S
A multi purpose control arduino mega shield
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The project is about developing a shield which can host a variety of interfaces such as
2 x stepper motors controlled with drv4498, drv8825 stepper modules
2 x PWM control motors driven from mosfet
1 x PWM control Pump - driven from mosfet
1 x PWM control FAN - driven from mosfet.
1 x PWM control Heater 12v - driven from Mosfet.
1 x 3 button keypad
1x hx711 weight sensor interface
1 x analog input sensing 0- 5v for diameter sensing
3 x servo control outputs
3 x NTC thermistor Sensing
1 x i2c VBus
1 x RGB status LED
1 X 12V input with poly switch fuse Protection
1 x 10 pin idc to interface with 12864 lcd shield
1 x Auxiliary 10 pin Serial ports x 3
1 x Expansion port for future upgrades.
