Application
A project log for 3D printed mini linear actuator
Need a mini linear actuator that is easy to print and implement in your robotics DIY projects? We got you
Jonathan DíazJonathan Díaz 06/01/2018 at 21:570 Comments
This is a simple application of the mini linear actuator, in this case is a robotic finger used in a robotic hand
