extruder gear update
A project log for protoDEV 3d printer
diy direct-drive extruder 3D printer running Klipper firmware
Michal WojciechowskiMichal Wojciechowski 12/14/2018 at 10:580 Comments
Way tougher than previous version. Lots of testing done. This one should be the last design... ;)
part list:
- DIN 931 M5 x 40mm (cut to 24mm)
- MR 105 ZZ
- MF 105 ZZ
- bondtech gear 5mm bore version
- bondtech_gear_v2.stl
