Project log - physical construction
A project log for Robotics sensor - 360 scan of environment
A turrent which is an array of 4 lidar sensor's along with two compasses and a servo that scan the environment and dump data into database.
stanStan 04/27/2018 at 11:201 Comment
OK Servo and current physical construction complete - POC so ugly as sin!
Stan wrote 04/27/2018 at 11:22 point
Did find something weird - the servo I have if I put say a Pulse of over 250, it becomes a continuous rotation servo - with lots of grunting noises!
