8-bit 74xx computer
Designing and building my own 8-bit computer from scratch with 74xx (TTL) logic chips
Having completed building my version of Ben Eater's 8-bit breadboard computer nearly a year ago, building my own Apple 1 clone, building and looking into the inner workings of the Gigatron kit and studying the book Digital Computer Electronics it is finally time to design and build my own computer from scratch!
The main goal is to learn how to do this and see if I can actually accomplish this build. The computer itself must be usable as a learning tool for people that want to learn about CPU architecture.
That means lots of blinking lights and switches!
The plan is to build an 8-bit computer with 74xx (TTL/CMOS) logic chips that supports 64 kB of memory and a clock speed up to around 1 MHz.
Status as of April 10th, 2019:
General architecture has been worked out as high level schematic.
Worked on instruction set, micro code, module documentation & general notes from time to time (see: Documentation). This is still work in progress! I'm planning to write a short piece of documentation on each of the modules, like I did for the Controller.
Circuit diagrams have been worked out in KiCad for all modules except for the Controller. These circuits were designed in KiCad (before the Logisim design was done) and not tested. All circuit diagrams need to be updated according to the Logisim design!
I've built a microcode compiler for the Controller's ROM image. This takes a source file which defines all the microcode and compiles it into a binary image that is loaded into the microcode ROM.
The 74xx Computer's instruction set has been implemented and its assembly language is fully documented. I've built an assembler to convert 74xx assembly to machine code.
The entire computer has been built in Logisim to verify that the way I had everything in mind is actually going to work.
While working on the Logisim design, I made several changes to the circuits that still need to be applied to the previously designed circuit diagrams.
  • Assembly Language Reference
    Ruud van Falier04/10/2019 at 09:14 3 comments
    The assembly language for the 74xx Computer has been finalized and documented: https://github.com/DutchMaker/TTL-computer/blob/master/Documentation/74xx-Assembly-Language.md
    Everything that is mentioned in the reference is also implemented in the Logisim circuit, the microcode compiler and the assembler.
  • Hello World
    Ruud van Falier04/08/2019 at 20:01 0 comments
    The entire instruction set has been implemented and the first Hello World program is running on the 74xx Computer in Logisim:
  • It's alive (in Logisim) !
    Ruud van Falier04/02/2019 at 15:03 1 comment
    The control unit is done and the first bits of microcode have been created.
    The computer is now running MVI, MOV and HALT instructions!
  • Back after hibernation
    Ruud van Falier03/26/2019 at 12:34 0 comments
    It's been a while, but the project is still alive! Lately I found the motivation to work on it again and the result is that the computer is now 95% finished in Logisim.
    It has been good to see that everything that was in my head is actually working for real, at least in simulation. Hopefully that is enough to keep me going!
    Status as of March 26th, 2019:
    Work done in chronological order:
    General architecture has been worked out as high level schematic (see: Architecture.pdf).
    Needs to be updated according to Logisim design!
    Worked on instruction set, micro code, module documentation & general notes from time to time (see: Documentation). This is still heavily work in progress! I'm planning to write a short piece of documentation on each of the modules, like I did for the Sequencer / Instruction Decoder.
    Circuit diagrams have been worked out in KiCad for all modules except for the Sequence / Instruction Decoder (see: Schematics-KiCad). These circuits were designed in KiCad and not tested.
    The entire computer is being built in Logisim to verify all the circuits and the way I had everything in mind is actually going to work. I'd say it's 95% done as far as Logisim design goes, but it can't be fully tested until the entire instruction set and all microcode has been worked out.
    While working on the Logisim design, I made several changes to the architecture and some to circuits. These changes still need to be applied to all previous work (architecture design, circuit diagrams, etc.)
    TODO's / Plans:
    • Rename the project to 74xx computer (it was named TTL Computer before, but it may technically not all be TTL).
    • Updated previously made documentation according to latest Logisim design.
    • Write new documentation on all modules
    • Finish the computer in Logisim with the entire instruction set working.
    • Build the computer in real life.
  • Updated architecture & instruction set
    Ruud van Falier05/08/2018 at 11:49 0 comments
    In the past weeks I have prototyped small parts of the computer, thought things over and realized that I had to make a few adjustments to the architecture and instruction set.
    Let me start with the progress that was made with the circuit diagrams.  The following diagrams have been completed and some of them are tested:
    • Clock [tested]
    • Program counter
    • A, B, C, D & Flags register [tested]
    • ALU [partially tested in Logisim]
    The following changes have been made to the architecture:
    • The X & Y registers have been renamed to C & D, nothing shocking here.
    • The ALU now has it's own internal accumulator register.
    • Input for the ALU can now come from the A, C & D register (and not just fixed from the A register). The second operand still comes from B.
    • Two outputs are now accounted for: decimal display (output 1) and serial (output 2)
    The instruction set has a few new and updated instructions:
    MOV [A,B,X,Y] [A,B,X,Y] Copy register N2 to register N1
    MVI [A,B,X,Y] #value Copy immediate value to register N
    LD [A,B,X,Y] $address Load register N with value at memory address
    ST [A,B,X,Y] $address Store register N value at memory address
    ADD [A, X, YN + B → N
    ADC [A, X, YN + B + 1 → N
    SUB [A, X, Y] N - B → N
    SBC [A, X, Y] N - B - 1 → N
    AND [A, X, Y] N & B → N
    OR [A, X, Y] N | B → N
    XOR [A, X, Y] N ⊕ B → N
    NOT [A, X, Y] !NN
    INC [A, X, Y] N + 1 →
    DEC [A, X, Y] N - 1 →
    SHL [A, X, Y] Shift all bits in register N to the left
    SHR [A, X, Y] Shift all bits in register N to the right
    RAL [A, X, Y] Rotate all bits in register N to the left
    RAR [A, X, Y] Rotate all bits in register N to the right
    CMP [A, X, Y]Compare register N to register B
    JMP $address Jump to memory address
    JZ $address Jump to memory address if zero flag is set
    JNZ $address Jump to memory address if zero flag is not set
    JC $address Jump to memory address if carry flag is set
    JNC $address Jump to memory address if carry flag is not set
    JEQ $address Jump to memory address if N = B
    JLT $address Jump to memory address if N < B
    JGT $address Jump to memory address if N > B
    CALL $address Jump to subroutine at memory address
    RET Return from subroutine
    NOP Do nothing
    HLT Halt execution
    IN Load data from input into register A (needs to be worked out)
    OUT [1, 2] [A, B, X, Y] Output data from register N2 on output N1
    (1 = decimal display, 2 = serial output)
    I'm currently waiting on more breadboards coming in for prototyping and slowly working out all the circuit diagrams in the meantime.
    More updates coming soon!
  • Instruction set
    Ruud van Falier04/29/2018 at 11:37 1 comment
    I've done a bit more work on defining the instruction set.
    These are the instructions that I'm planning to implement and that should be supported by the architecture that has been worked out so far:
    MOV [A,B,X,Y] [A,B,X,Y] Copy register n1 to register n2
    MVI [A,B,X,Y] #value Copy immediate value to register n
    LD [A,B,X,Y] $address Load register n with value at memory address
    ST [A,B,X,Y] $address Store register n value at memory address
    ADD A + B → A
    SUB A - B → A
    AND A & B → A
    OR A | B → A
    XOR A ⊕ B → A
    INC A + 1 → A
    DEC A - 1 → A
    RAL Rotate all bits in register A to the left
    RAR Rotate all bits in register A to the right
    NOP Do nothing
    HLT Halt execution
    OUT Output data from register A (needs to be worked out)
    I haven't given much thought to input & output yet, so I might need a few specialized instructions in the future to cover that part.
  • Architecture
    Ruud van Falier04/27/2018 at 19:53 0 comments
    Most of the computer's architecture has been worked out (at least on paper...)
    Here is a schematic overview of the entire architecture:
    [View Architecture Overview]
    Let me explain what I have in mind:
    • There is an 8-bit data bus and all the registers are 8-bit.
    • 64 kB of memory can be accessed using a 16-bit address bus, managed by the memory access register.
    • The memory consists of 16 kB ROM and 48 kB RAM.
    • The program counter is 16-bit and can be loaded using the X and Y register.
      The program counter output can be loaded into the memory access register.
    • The X and Y registers can also be used to load a 16-bit memory address directly into the memory access register.
    • The A(ccumulator), B, X and Y registers can all be used to read and write to the data bus.
    • I'm going with the 74181 for the ALU (which some will consider to be a shortcut).
    • Input for the ALU comes from the Accumulator and B register, output is put on the data bus.
    • The stack pointer is used while storing return addressed for CALL instructions. It's basically a 4-bit binary counter and the module outputs 16-bits in total of which the first 12-bits are always set to 1 and last 4 bits come from the counter. This means the stack is stored at FFF0-FFFF in RAM. Considering the fact that memory addresses take up 2 bytes, the stack allows for up to 8 nested subroutine calls.
    • The ROM can be disabled. I want to be able to use this computer for educational purpose and have the option to manually put a program and RAM (using switches) instead of always booting from ROM.
    • For the same educational purpose, but also for debugging purpose, the clock can run in several modes: single-step, slow variable mode (1 to 15 Hz) and turbo mode (1 MHz).
    • Functionality for input and output modules still has to be determined.
    • The computer will be driven by micro code. The instruction set is still under construction.
    • Instructions consist of 1 to 3 bytes: 8-bit opcode and 16-bit data.
    I really want to be able to use this machine to teach others about CPU architecture.
    I'm planning to add LED indicators to all the modules in order to visualize the data flow.
    Aside from that the machine can be single stepped and programs can be loaded straight into RAM using switches.
View all 7 project logs
Peabody1929 wrote 04/02/2019 at 16:36 point
How do you plan to implement the instructions?  WIll they be hardwired or microprogrammed?  Hardwired is easy for a Load or Store instruction but difficult for a multiply instruction.
Ruud van Falier wrote 04/10/2019 at 13:56 point
Hi Paebody, it's microprogrammed. I'm not very experienced at this so I need to be able to make changes as I go.
roelh wrote 04/28/2018 at 08:34 point
Hi Ruud,  nice project !
I suggest that you first make a simulator and write a few small programs. That might point to things that can be improved in the architecture or microcode. In my https://hackaday.io/project/11012-risc-relay-cpu I changed the instruction set four times., because I missed certain instructions during programming.
Ruud van Falier wrote 04/28/2018 at 10:43 point
Hi Roel, thanks!
Very good advice on the simulator, I will definitely take that into consideration. I will also take a look at your project and see if I can take some learnings from that.
