In the past weeks I have prototyped small parts of the computer, thought things over and realized that I had to make a few adjustments to the architecture and instruction set.
Let me start with the progress that was made with the circuit diagrams. The following diagrams have been completed and some of them are tested:
- Clock [tested]
- Program counter
- A, B, C, D & Flags register [tested]
- ALU [partially tested in Logisim]
The following changes have been made to the architecture:
- The X & Y registers have been renamed to C & D, nothing shocking here.
- The ALU now has it's own internal accumulator register.
- Input for the ALU can now come from the A, C & D register (and not just fixed from the A register). The second operand still comes from B.
- Two outputs are now accounted for: decimal display (output 1) and serial (output 2)
The instruction set has a few new and updated instructions:
| MOV [A,B,X,Y] [A,B,X,Y] | Copy register N2 to register N1 |
| MVI [A,B,X,Y] #value | Copy immediate value to register N |
| LD [A,B,X,Y] $address | Load register N with value at memory address |
| ST [A,B,X,Y] $address | Store register N value at memory address |
| ADD [A, X, Y] | N + B → N |
| ADC [A, X, Y] | N + B + 1 → N |
| SUB [A, X, Y] | N - B → N |
| SBC [A, X, Y] | N - B - 1 → N |
| AND [A, X, Y] | N & B → N |
| OR [A, X, Y] | N | B → N |
| XOR [A, X, Y] | N ⊕ B → N |
| NOT [A, X, Y] | !N → N |
| INC [A, X, Y] | N + 1 → N |
| DEC [A, X, Y] | N - 1 → N |
| SHL [A, X, Y] | Shift all bits in register N to the left |
| SHR [A, X, Y] | Shift all bits in register N to the right |
| RAL [A, X, Y] | Rotate all bits in register N to the left |
| RAR [A, X, Y] | Rotate all bits in register N to the right |
| CMP [A, X, Y] | Compare register N to register B |
| JMP $address | Jump to memory address |
| JZ $address | Jump to memory address if zero flag is set |
| JNZ $address | Jump to memory address if zero flag is not set |
| JC $address | Jump to memory address if carry flag is set |
| JNC $address | Jump to memory address if carry flag is not set |
| JEQ $address | Jump to memory address if N = B |
| JLT $address | Jump to memory address if N < B |
| JGT $address | Jump to memory address if N > B |
| CALL $address | Jump to subroutine at memory address |
| RET | Return from subroutine |
| NOP | Do nothing |
| HLT | Halt execution |
| IN | Load data from input into register A (needs to be worked out) |
| OUT [1, 2] [A, B, X, Y] | Output data from register N2 on output N1 (1 = decimal display, 2 = serial output) |
I'm currently waiting on more breadboards coming in for prototyping and slowly working out all the circuit diagrams in the meantime.
More updates coming soon!
Ruud van Falier
