Rotor II
A project log for Enigma Machine
A simplified Enigma Machine build using 3d printed parts and printed circuit boards
lolsbornLolsborn 05/04/2018 at 16:470 Comments
Got the first rotor put together last night.  Just waiting on pogo pins.  I updated the Ringstellung so that it can accept a M3 set screw to hold it in place if the friction fit isn't adequate.
The letters are printed separately in a single strip.  I print the white part and then swap to black filament then cut the letters from the thin backer and super glue them to the ring.
