Waste to Energy
Feed the monster waste and get electricity.
pjkPJK
Gasification of waste generates useful gas. This is then fed to a sterling engine that then generates electricity and charges up batteries. Free juice for all. Its been done many times before but what makes this special is the feed stock.
Consumable product moves down the throat where partial combustion takes place in a fire grate. Some combustion provides the heat while the unburnt gas products are whisked away to do thine infernal bidding. The partial burning takes place in an oxygen deprived atmosphere.
  • Where its at.
    PJK • 08/15/2014 at 21:35 • 0 comments
    The body of the unit is made. The hopper nears completion. The outlet section requires plumbing in to a non existent gas cleanup system. From here we need the burner, fed by pressurized syngas, providing power to the sterling engine that charges batteries. Some micro controller can monitor the whole system and assure that feed stock does not run dry.
View project log
ganzuul wrote 07/25/2014 at 16:15 • point
Can you already list some components?
matt.syme wrote 07/18/2014 at 15:59 • point
Sounds interesting, but I need more information!
Jamie Krasnoo wrote 07/11/2014 at 03:38 • point
I would expect plastic is the feedstock.
Adam Fabio wrote 07/01/2014 at 04:58 • point
You're off to a great start with this idea - Thanks for entering The Hackaday Prize! Try to give us some more information on your Gasification system. what is this magic feedstock of which you speak? (and where is the monster?)
