Display Driver
A project log for Tileable 8x8 LED matrix
1.0" LED Dot Matrix 8X8 Cascadable Module with SPI interface
christoph-tackChristoph Tack 05/10/2018 at 19:340 Comments
The driver should have SPI or I²C interface and allow dimming.
SPI
I²C
To avoid that the 74HC595 has to source the current for the LED array, transistors will be used, as switches.  Three transistor types could be used : PNP, NPN and PMOS:
