First test
A project log for Tileable 8x8 LED matrix
1.0" LED Dot Matrix 8X8 Cascadable Module with SPI interface
christoph-tackChristoph Tack 06/23/2018 at 14:110 Comments
PCB Assembly
There's not much to report here.  All parts fit correctly.  I suspect ALLPCB from drilling the holes for the PCB studs a bit too large.
Pin 1 of the pin headers was not marked in the silkscreen of the PCB.  This will be fixed in the next revision.
Electronics
Before connecting power, all connections should be checked.  I felt confident enough to skip this step.  The schematics don't contain any new circuitry to me.
Unicorn! Revision 0 is fully functional.
Firmware
The Adafruit GFX is quite nice.  This will be used to provide high level functionality for drawing lines, character sets etc...  I only need to write a low level driver that can color a pixel at the desired coordinate.
It didn't take too long to get this working.
Next thing is adding dimming functionality.
