Portable Raspberry Pi with LCD + keypad
raspberry pi inside a pelican case with 3d printed parts
this box is for a rugged portable unit
i wanted to make this box to run FPP for my lighting display and for a rugged portable unit we could use while camping.
the box takes 12v in i have set it up so i could use a drill battery to power the box the screen takes 12v and to get the 5v i need to the PI i used a LM2596
JPEG Image - 45.99 kB - 10/06/2016 at 19:14
Preview
JPEG Image - 43.47 kB - 10/06/2016 at 19:14
Preview
JPEG Image - 43.85 kB - 10/06/2016 at 19:14
Preview
JPEG Image - 45.15 kB - 10/06/2016 at 19:14
Preview
JPEG Image - 47.46 kB - 10/06/2016 at 19:14
Preview
View all 13 files
  • 1 × Pelican 1150 Case
  • 1 × Raspberry Pi 3
  • 1 × Delvcam DELV-HD7
  • 1 × VELCRO Brand - Industrial Strength - 2" x 4"
  • 1 × LM2596 DC-DC Buck Converter Step Down Module Power
View all 6 components
  • 1
    Step 1
    download STL files
  • 2
    Step 2
    print out each STL file once except for the buttons print out 5 buttons
    ^ pi with screen L ^
    ^ shorter L ^
    ^ screen spacer ^
    ^ raspberrypi middle with 5 bottons ^
    ^ raspberrypi bottom ^
  • 3
    Step 3
    super glue case pi with shorter L with case pi with screen L
    set aside for latter
View all 11 instructions
