Universal Speed Reducer
Double Stage Cycloidal Drive for Robotic Platform
The goal of this project, it's to create a lowcost universal speed reducer for robotics applications
This project is on development.
All the pieces are 3D printed with an Ultimaker 2 with an infill of 30% and a quality of 150 microns but you can make your own settings or also machine them.
If you have questions or comments, post it in the comment below, I will enjoy .
Gearwheel 20 teeth.stp
stp - 900.15 kB - 06/12/2018 at 19:04
Download
Gearwheel 19 teeth.stp
stp - 824.74 kB - 06/12/2018 at 19:04
Download
Motor Base Aerodrive Turnigy 4250.stp
stp - 134.12 kB - 06/12/2018 at 19:04
Download
Top.stp
stp - 75.48 kB - 06/12/2018 at 19:04
Download
Head.stp
stp - 145.54 kB - 06/12/2018 at 19:04
Download
View all 13 files
  • 1 × Base
  • 1 × Head
  • 1 × Top
  • 1 × Gearwheel 20 teeth
  • 1 × Gearwheel 19 teeth
View all 10 components
  • 1
    Gearwheels assembly
    Components list :
    • 1 x Gearwheel 20 teeth
    • 1 x Gearwheel 19 teeth
    • 2 x Roller Bearing 8x22x7
    • 6 x Screw M3x10
    1. Insert the roller bearing in each gearwheel
      2. Screw the six M3x10
  • 2
    Base assembly
    Components list :
    • 1 x Base
    • 1 x Roller Bearing 8x22x7 with stop
    1. Insert the roller bearing in the base
  • 3
    Head assembly
    Components list :
    • 1 x Head
    • 1 x Needle Roller Thrust Bearing 40x60x3mm
    1. Insert the roller bearing and the needle roller thrust bearing in the base
View all 9 instructions
Ian Pritchard wrote 05/20/2019 at 20:58 point
Hi! What is the gear reduction ratio on this, and the torque? thanks!
