Note Currency Recognizer
Note currency recognizer device helps visually impaired people to know the value of money they have in their hand via automated voice.
Note currency recognizer serves only local Malaysian bills which are RM 1, RM 5, RM 10, RM 20, RM 50 and RM 100. The RGB color sensor is coded to recognize a region of the bill while Arduino micro-controller process the information from the color sensor. The speaker module is activated and the voice is played based on the stored voices of each bill inside the MP3 module(DF Miniplayer). A Lippo rechargeable battery of 7.4v and 1300mAh is used to powered the note currency recognizer.
Performance
Focused on accuracy and its functionality while designing this device. In order for it to work efficiently, immense effort was put on operating the device carefully and ensure it was operating optimally.
Durability
For the product to be long lasting and durable, it was made sure that high quality components is being used and also the casing is made by good quality design.
Affordability
This is one of the main criteria for our design.  It was a great deal to reduce cost as low as possible so that the project can be completed within stipulated time.
Portability
The device is designed to make everyone’s life easier especially for the visually impaired people. When the device is made portable, it is easier for people to carry it around everywhere they go
Marketability
Factors that will increase the marketability of this device are it must be lightweight, rechargeable and designed with fancy casing.
CODING.docx
Arduino Code
document - 21.53 kB - 04/30/2018 at 12:24
Download
  • 1 × RGB COLOUR SENSOR complete color detector including RGB sensor chip and it can detect and measure a nearly limitless range of visible colors
  • 1 × ARDUINO UNO Arduino is a microcontroller-based kits of computer hardware for building digital devices and interactive objects that can sense and control objects and the physical world. It read pulses from a scanner that detect the currency; the sketch of an image will be uploaded to the Arduino using the scanner then some coding will be inserted by special software to identified or make a differences in the value of each notes
  • 1 × SPEAKER Speaker is a device that give an output from our system.It gives a sound of each value of the note that we inserted under the colour sensor.It connected with the system and get the code from the Arduino to be functioned
  • 1 × MP3 MODULE(DF MINI PLAYER) it is a small and low price MP3 module with an simplified output directly to the speaker.It also can be used as a stand alone module with attached battery, speaker and push buttons or used in combination with an Arduino UNO or any other with RX/TX capabilities.The audio data sorted by folder and can supports up to 100 folders, every folder can hold up to 255 songs
  • 1 × RECHARGEABLE BATTERY it is use to power up all the components.The battery used is Lippo battery of 7.4v and 1300mAh
View all 8 components
  • 1
    Part/Items
    The Arduino, color sensor, speaker, MP3 module and jumper wires have to be areadily available
  • 2
    Schematic diagram
    Design of schematic diagram to enable best possible way of arranging the components
  • 3
    Fabrication of box
    A portable box is needed to be design and fabricated whether it is DIY or machine cut. Material used depends on individual. A rectangle has be cut at any side of the portable box to allow notes to be inserted.
View all 6 instructions
humzii1129 wrote 02/20/2024 at 09:35 point
https://mepcobillonlinecheck.pk/
zoemiles2233 wrote 6 days ago point
Do not place it directly. You can not beat me bro. Im here fescoonlinebill.net.pk
naeematta046 wrote 03/20/2023 at 13:08 point
I am currently in search of a skilled developer who can create software for my website, onlinebillcheck.pk. The software will be used to allow users to upload images of their currency notes and check if they are real or fake. This feature will be a valuable addition to our platform, providing our users with an additional level of security and peace of mind. We are looking for a developer with experience in creating secure and reliable software solutions, and who is committed to delivering high-quality results. If you are interested in this project and have the necessary skills and experience, we would love to hear from you.
PlusPackages.com wrote 05/20/2021 at 10:41 point
This is the best tool for anyone if he is interested in doing the money business:
k electric duplicate bill tool: https://ptclbills.com/k-electric-duplicate-bill/
https://pluspackages.com/zong-internet-packages
jiyaleni wrote 11/27/2020 at 14:59 point
I really like this model. How can it be implement it on any tool website? Can I test it on my blog tool https://findanybill.com/
naziahnajmi wrote 10/16/2020 at 09:28 point
sir can i know about the coding ?
kaillinux770 wrote 01/10/2019 at 13:11 point
sir, can u pls upload clear cricut diagram
Ifedapo Abdullahi wrote 02/04/2019 at 15:19 point
which particular circuit diagram are you referring to?
Christine wrote 09/07/2018 at 11:33 point
what is the use of the sd card?
what the wattz of the speaker and the resistor what ohms? i building a mini mp3 player in arduino,
Ifedapo Abdullahi wrote 09/07/2018 at 11:45 point
SD Card to store the automated voice; it's a generic speaker and it can be of any reasonable audible watt and the resistor value is 100 ohms.
What is the application of your project about?
Christine wrote 09/09/2018 at 07:34 point
it similar of your project, school project in capstone 2 subject but I having problem to get the value of currency we using Philippine money, and when I make a basic mp3 using dfplayer mini, I have an error about the libraries do you have a link of dfplayer library
Christine wrote 09/09/2018 at 07:54 point
Exit status 1
Error compiling for board Aduino/genuino uno do you about this problem please help me
Ifedapo Abdullahi wrote 09/09/2018 at 14:02 point
Well trying downloading the library for the minimp3 module. It should be in the menu where you can download the extended arduino libraries. Try that, it should work.
Christine wrote 09/19/2018 at 13:04 point
How did you put a this value in if else condition, this is the money in the phil. 20,50,100,200,500,1000, 1000 is the higher bill, please help me about this problem
Ifedapo Abdullahi wrote 09/19/2018 at 13:34 point
If you want to put those values in if-else you have to be sure that you have rightly got the right output from the sensor you are using(color sensor, image ) then using the boundary condition of either the color output in RGB or image classification you assign the currency value. i.e: test the what colour range you get from color sensor by placing the color sensor on the currency(200) then you take not of it then you add it in the if-else condition.
Christine wrote 09/20/2018 at 19:58 point
v1: 232
16:19:46.121 -> v2: 251
16:19:46.121 -> v3: 267
16:19:46.121 -> This is 100 Peso(s)
v1: 308
16:19:50.226 -> v2: 321
16:19:50.226 -> v3: 313
16:19:50.226 -> This is 200 Peso(s)
It printed out but the automated voice cannot be played, i save the audio format 0001.mp3,, thank you so much for your help..
The audio length is 1second.
Ifedapo Abdullahi wrote 09/21/2018 at 01:38 point
since you have your output printing for the color sensor. the only thing you have to do now is to associate the mp3 playback for each currency value inside each if-else condition you have created. This makes the code aware that you are trying to associate a playback from the automated voice inside the mp3 sdk card..
Ifedapo Abdullahi wrote 09/21/2018 at 01:41 point
For further reference on the DF Mini Player you are trying to set. this page might help you more: https://github.com/Makuna/DFMiniMp3
ActualDragon wrote 04/30/2018 at 16:49 point
what about bitcoin?
Ifedapo Abdullahi wrote 05/01/2018 at 12:00 point
Do you have any suggestion? You can give an idea?
I really do have some idea about it but I'm stuck in one of my running websites. Can you people suggest me how to handle it. https://fescoonlinebill.net.pk/
