Power supply
A project log for Modular Humanoid Robot "MARB"
Meet MARB, a modular humanoid robot you can build yourself
m-bindhammerM. Bindhammer 05/11/2018 at 20:360 Comments
Time to take in some considerations about the power supply of MARB. I am using a 9.6 V, 5000 mAh NiMH racing pack battery. Obsolete, you will think. Why not using a Li-Ion or Li-Po battery? I can tell you. NiMH batteries are much easier to handle than Li-Ion or Li-Po batteries. They forgive mistakes Li-Ion or Li-Po batteries won't. They may have less energy capacity and a memory effect, but they normally don't burn or explode when treated the wrong way.
Battery mounted on the robot:
3-D printed bracket for the ON/OFF switch:
Another 3-D printed part for the power distribution and motor control module:
Assembled and partly wired module. The LM 2596 based voltage regulator powers the micro controllers, the other step-down DC-DC converter the servos.
