Micro tutorials for microcontrollers
Tutorials and advice for those who are new in developing the MCU programming skills
Over the years I worked a lot with microcontrollers. I know there are a lot of technical persons out there surfing these projects and these forums who never tried programming an MCU. Having said so, I thought it is a good Idea to have some tutorials posted here, just in case someone is interested.
ASM programming a PIC16F628 Hello World
Check the Logs area for the source code.
More ASM programming: How to make a delay loop and blink some LEDs
Check also the Logs for the source code.
MSP430 C++ Hello World
MSP430G2553
Got a PICkit clone and you don't know how to connect it to the MPLAB suite?
  • MSP430 C++ Hello World MSP430G2553
    Marius Taciuc05/03/2018 at 04:25 0 comments
    MSP430G2553 programming with a Hello World code. C++ on IAR Embedded Workbench.
    Code here:
    // Basic MSP430 Hello World
    #include "msp430G2553.h"
    #define G_LED BIT6
    #define R_LED BIT0
    int i,j,delay;
    void delay_time(int);
    void delay_long(int);
    void main(void){
    WDTCTL = WDTPW + WDTHOLD; // disable watch dog timer
    DCOCTL = CALDCO_16MHZ;    // set internal oscillator at 16MHz
    BCSCTL1 = CALBC1_16MHZ;   // set internal oscillator at 16MHz
    P1OUT = 0x00;
    P2OUT = 0x00;
    P1DIR = 0xFF; // Set all as outputs
    P2DIR = 0xFF; // Set all as outputs
        for(;;) {
        P1OUT |= G_LED;      // Enable = 1
        delay_long(delay);
        P1OUT &= ~(G_LED);   // Disable = 0
        delay_long(delay);
    //-----------------  Functions & Procedures  -----------  Functions & Procedures  -----------  Functions & Procedures  -------------
    void delay_time (int delay){      //----------------------------------------- Delay---------------------
         do delay--;
         while (delay != 0);
    void delay_long (int){            //--------------------------------------- Delay long------------------
                int j;
                j = 100;
             do{
                delay_time(5000);
             j--;
             }while (j != 0);
  • ASM Hello World Program for PIC16F628 / PIC16F819
    Marius Taciuc05/02/2018 at 05:51 0 comments
    Programming a PIC16F628 microcontroller using MPLABX and PICkit3 - A Hello World Program demonstrating the basic principles of writing a piece of ASM code. The LEDs on the PORTB are lighting up according to some pressed buttons on the PORTA used as an input here.
    For details about the hardware used in this video, refer to the following website: www.funelectronicstoday.com
    The result code, in case you want to copy-paste it:
    ; Hello world basic 16F628 ASM program
     RESET CODE 0x00
     #INCLUDE P16F628A.inc ; put angle brackets here
     __CONFIG _HS_OSC & _CP_OFF & _LVP_OFF & _BODEN_OFF & _MCLRE_ON & _PWRTE_OFF & _WDT_OFF
     ; THIS PROGRAM WAS DESIGNED FOR 20 MHZ OSC
     ;_XT_OSC             : EXTERNAL 4MHZ
     ;_HS_OSC             : EXTERNAL 20MHZ
     ;_INTRC_OSC_NOCLKOUT : INTERNAL 4MHZ
     CBLOCK 0X20 ; THIS IS HOW YOU DECLARE A BLOCK OF VARIABLES
        NVAR1, NVAR2
     ENDC
     CLRF PORTA ;SET THESE PINS BEFORE YOU ACTUALLY CONFIGURE THEM
     CLRF PORTB
     MOVLW 0X07    ; DISABLE THE COMPARATORS AND ENABLING THE PINS FOR
     MOVWF CMCON   ; FUNCTIONING AS I-O
     BCF STATUS, RP1 ;SETS BANK1
     BSF STATUS, RP0 ;
     MOVLW B'00111111' ;SET PINS 0 - 4 AS INPUTS ; TRIS 5 AS 1 ALWAYS
     MOVWF TRISA
     MOVLW 0X00 ;SET PINS 0 - 7 AS OUTPUTS
     MOVWF TRISB
     BCF STATUS, RP0 ;
    ;MAIN LOOP----------------
    REPEAT
     MOVFW PORTA
     MOVWF NVAR1
     MOVFW NVAR1
     MOVWF PORTB
     GOTO REPEAT ; END OF MAIN LOOP
     END
  • Delay loop code in ASM PIC16F628 / PIC16F819
    Marius Taciuc05/02/2018 at 05:46 0 comments
    In the previous videos I've been explaining how to initialize the ports of the PIC16f628 microcontroller. This other video shows how to write a delay loop and blink some LEDs for fun. The code of the main loop and of the delay loop is listed below in case you want to copy-paste it:  Check also funelectronicstoday.com for more fun projects.
    REPEAT
        MOVLW 0X00
        MOVWF PORTB
        CALL DELAY
        MOVLW 0X01
        MOVWF PORTB
        CALL DELAY
        MOVLW 0X02
        MOVWF PORTB
        CALL DELAY
        MOVLW 0X04
        MOVWF PORTB
        CALL DELAY
        MOVLW 0X08
        MOVWF PORTB
        CALL DELAY
        CLRF PORTB
        CALL DELAY
    DELAY
     CLRF DELAY1
     CLRF DELAY2
    DELAYLOOP
     DECFSZ DELAY2,F
     GOTO DELAYLOOP
     DECFSZ DELAY1,F
     GOTO DELAYLOOP
     RETURN
View all 3 project logs
