4 ws2812b, 1 mcu, maybe timekeeping chip
They kind of belong together, I've taken the neopixel 7 segment display from the "unexpected maker" tindie shop and adapted my code to show on his display.
And since it's a project of a youtuber and a binary clock, here's another video where I've build up the BCD crap clock by David Watts :)
So it's pretty tough to show grey vs. white and brown vs. orange and I thought to help with that I'll take a WS2812B 4x4 matrix and make it a binary coded decimal clock.
:) The plan was color encoded decimals on 4 digits at first, so I wouldn't need gold and silver anyway... but with the change of plans making it binary encoded, it kinda works for me like this. I like the mechanical idea but don't know how this could be done in a small manner for a watch.
4 digits requires 4 rings which means that they should be mapped to 1% or better resistors with 3 significant digits and 1 multiplier.
There shouldn't be gold/silver... Those are for 5% or 10% resistors with only 2 significant digits and 1 multiplier ring while the 4th one is tolerance.
It was just a thought I had. To get twelve numbers use the 0-9 for the first 10 numbers (0 maps to 12 o’clock) then add the precision band colors for the othe two. A standard watch face can be used, but with colors instead of numbers. Not Uber-geek (Darko level😉) but still a way of using the color codes and keeping them fresh in memory. If I wanted to mess with people asking the time I could just rotate the watch😀 I was thinking of trying it on a cheap Chinese pocket watch I have.
ahhh so you mean basically add a rainbow colored clock face to a standard analog watch?
Neat idea :-) Might try that with IO but I would need a backpack ;-)
So I did my own take on the resistor code watch, which is in this upcoming No Starch book... https://nostarch.com/LEDHandbook... but basically I used a pair of 8-LED NeoPixel sticks to show the time, and you have to multiply the position of the LED by the color. So for instance, if it's 4PM (16) you would light up the 4th pixel with a yellow color -- 4x4. I can't wait to see what you do with this project, Dave!
interesting :) do you have a picture you're allowed to share? so what do you do with 16 LEDs then? I thought about adding seconds as well to make it 6 leds - do you also have the date on there with a full year? Or is this your way of going around white, grey and black?
Here it is... good luck with your project! https://twitter.com/johnbaichtal/status/993153846452084736
Only use Blue, Red, Yellow, and Green as those are the most readily differentiated from each other. Brown is 1, right? But how do you show brown on a LED? For that reason I swapped in Blue for 1.
My brown sadly is a slightly darker orange and the grey is just a not so white white :D
Would the time be rounded to the nearest E48, E96 or E192 values? :P
Great Dave! I love clock projects.
Be sure it can morse transmit the time for color blind people (only joking, :D )
well it could at least blink a bit for cheating and learning but I think color blind people wouldn't buy a color based clock? but why be exclusive when you can be inclusive :)
This is a great idea! I'm slow with color codes and this would definitely get me to practice.
K.C. Lee
Pete Hoffswell
Mark VandeWettering
Ken Yap
I love this project and idea! I am going to go a little “555” on this comment, no disrespect meant by it.
Since colors (gray, black, gold, silver) are so hard to represent using RGB LEDs, would you be better off with an analog watch with a color wheel for the hours? (Using gold and silver for 10 and 11.) Maybe use conventional arms or LEDs for minute and seconds? Analog movements are so energy efficient and even if you used LEDs for the minutes and seconds when you pressed a button you would still have a low power option.
