Brain23_Buck_SCH.PDF
Brain23 is the MCU board for PAC5223 based PowerPACk modules. Brain23 offers access to UART communications, SWD programming/debug, potentiometer interface and Hall Sensor interface. It matches with any power FET board, such as the PowerPACk23_FETs_PMSM or the PowerPACk23_FETs_HB
Adobe Portable Document Format - 328.68 kB - 05/04/2018 at 13:16
Preview
Download
TO247_SCH.PDF
TO247 based Power PACk designed to mesh with the Brain32 controller module. Contains the Power FETs, SENSE resistors, gate drive resistors, phase output voltage dividers, and power connectors.
Adobe Portable Document Format - 245.53 kB - 05/04/2018 at 12:56
Preview
Download
Brain32_SCH.PDF
Brain32 is the MCU board for PAC5232 based PowerPACk modules. Brain32 offers access to UART communications, SWD programming/debug, potentiometer interface and Hall Sensor interface. It matches with any power FET board, such as the TO247_PACK or TO220_PACK
Adobe Portable Document Format - 436.13 kB - 05/04/2018 at 12:48
Preview
Download
Toolio_SCH.PDF
Stand alone tri phase BLDC motor driver. Intended for small power tools with as much as 20V nominal voltage. 40V Abs Max. 15A RMS (300W or less).
Adobe Portable Document Format - 374.23 kB - 05/04/2018 at 01:14
Preview
Download
