After cutting and bending the sheet metal, I welded on a base made from round solid stock. Then I did some faux weathering, which looks OK but didn't exactly come out as I wanted.
But overall I'm very happy with the results!
Ever wonder if a scroll saw blade meant for wood can be used on metal? Yes it can! I made this replica MLK statue using 16GA steel.
