The application for 3D glasses can mean becoming somewhat independent of all the different stereoscopic shutterglass 3D solutions out there.
There are a whole bunch of different 3D active shutterglass solutions out there. They typically use VGA connections to sync on, or sync internally with a graphics card driver.
The sync signal reaches the glasses via a special connector on some graphics cards, or an IR transmitter in the display or in a USB dongle (like NVidia 3D Vision).
Lately, the use of special displays or proprietary dongles is the most common since VGA is not used for most 3D display solutions anymore.
With this project, all you need on the software side is a driver (this could be a 3rd party one like Tridef/IZ3D or a proprietary one like NVidia 3D Vision) that can drive a suitably fast LCD/CRT/projector/whatever in frame-sequential mode. Then, using this sync extractor and a suitable set of shutter glasses, you can handle everything else yourself.
SanderV
David Scholten
nullvalue
colton.baldridge
Arthur Admiraal
http://www.mtbs3d.com/phpBB/viewtopic.php?f=26&t=13495
That used the IZ3D driver, which had a special mode to display a block of pixels in the corner of the screen that would change color (black/white) with the left/right eye images. Picked it up with a phototransistor and synced the glasses on that.
It worked quite well, but IZ3D since then has gone out of business, and the other main 3rd party drivers don't have the pixel feature... and it wasn't a very elegant solution!
