Motor Modification
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
paul-gouldPaul Gould 05/10/2018 at 15:262 Comments
The Hobbyking range of Multistar Elite Brushless motors are powerful and lightweight.  I have paid between AU$25 and AU$75 for the Multistar Elite 5008. They do need to be modified to be integrated into the robot actuator. The shaft has been replaced with a longer one (with a hole) and the base has been reduced in size and weight.
dekutree64 wrote 06/29/2019 at 10:11 point
Can you explain how you cut the base? Dremel wheel is the best tool I can think of for it, but those things are so jumpy and explode frequently, it seems unlikely to make it through the whole operation without damaging any wires.
Paul Gould wrote 06/29/2019 at 10:28 point
I use a hacksaw. and hand file. I put a .5mm sheet of Al between the wires and the piece I'm cutting.
I now use the Gartt ML5010 3000KV motor now which has a small base already. It is also cheaper and in-stock.
