Robot Quadruped Tail
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
paul-gouldPaul Gould 06/08/2018 at 15:410 Comments
Tail Design
3x Mini Actuators (5 Joints)
Joint 1 is tail "wag"
Joint 2 has figure 8 pulley to Joint 3 and the angle is opposite
Joint 3 is actuated up/down
Joint 4 is actuated up/down
Joint 5 has a figure 8 pulley to Joint 4 and the angle is opposite
Distance between Joints is 100mm
Motors are Multistar Elite 3508
The tail is used for the quadruped's balance.
Was thinking about putting an end effector, camera or gripper
