Actuator Testing
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
paul-gouldPaul Gould 06/01/2018 at 15:310 Comments
Testing using the Brushless motor, Cycloidal gearbox, Position sensors, Controller and LiPo Battery
My prototype actuator has a tested no load speed of 60deg in 0.2sec @ 12V, 4A @ 50 Max PWM
I have not tested the max stall torque but 10Nm is currently suitable for my needs.
The motor can handle 600W (22V @  27A) and the brushless controller can handle 4000W (40V @ 100A) (both dependent on cooling)
In comparison, the Dynamixel MX-106R is the servo I wanted as it had 100kg/cm (10Nm) stall torque but it's no load speed is 55RPM and it cost ~US$500
