Making the Smaller PSOC4 Brushless Actuator Controller
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
paul-gouldPaul Gould 01/22/2020 at 16:500 Comments
Boards got delivered from JLC PCB. Ordered on Monday night, arrived in Australia on Monday morning.
10x 4 layer boards + Shipping = AU$35.75
Internal Power planes were checked and all seamed fine. Next time I will order gold boards.
Via hole centering is slightly better than the last boards I had made at PCBWay.
Surface finish is not as good, but I think I ordered a better finish last time.
Silkscreen is clear and much better aligned.
I am happy with the boards.
I populated the board by hand using a soldering iron, solder and solder wick.
I will order a stencil next time or just get JLC to populate the PCB. I may still order a stencil for the remaining boards.
I took two nights to populate and 90% test the boards.
Motor is running from this board, so the follwoing are working
Next to test
