Trying out the first PCB
A project log for STM32 Robot Arm Controller
Provides power, PWM voltage level conversion, and a Wii Nunchuck connector. Designed to work with the EEZYbotARM MK2.
ville-tiukuvaaraVille Tiukuvaara • 05/19/2018 at 22:29•0 Comments
I got the PCBs in the mail this week and soldered one up using the reflow skillet method. So far, it is mostly working. The main issue that I have come across so far is that the power enable signal, which is pulled up to 5 V, has its gate a few hundred millivolts too low when it should be high, so the PFET that it is controlling does not turn off.
The PFET turns on the motors when POW_EN is pulled low.
I am using pin PA4 on the STM32L476 in open drain mode to control it. I thought that this should work, but unfortunately this pin is not a 5 V tolerant pin. Looking at the datasheet, there are protection diodes on the pin that I believe are causing the issue. This means that the power enable signal unfortunately does not work on this revision of the PCB. It should be connected to a 5 V tolerant pin, also called a "TT" pin in the datasheet, such as PA2.
On a more positive note, the level-shifting circuitry is working. After debugging the above issue I had damaged the top copper layer so I did a messy soldering fix shown below to reconnect the 5V pull-ups. The NFETs convert 3.3V PWM from the micro controller to 5V for the servos. Note that since the FETs are inverting the duty cycle of the PWM signal also needs to be inverted. I was successfully able to move a servo motor, and have started putting together some firmware using the online Mbed compiler. The project is here.
An ugly fix shorting a pin of R7 to Q2 to R13. This is on the 5 V net. Q2 is useless since it would never turn off anyways.
The NFETs convert a 3.3 V PWM signal to 5V. You can control up to 6 servos.
Lastly, I also checked the Nunchuck interface. Unfortunately, the connector is slightly too narrow, so I had to sand it down a bit. But I2C communication worked great using the WiiNunchuck library on Mbed.
