PCB Assembly
A project log for 4B Robot
A 6cm 4-legged Ball Robot
carl-bugejaCarl Bugeja 07/19/2018 at 21:542 Comments
All the components have arrived and today i started soldering the pcb!
I’m quite happy with the result 🙂 The only issue i have found till know is with the USB socket. For some strange reason the slots for its alignment pins were not generated in the NC drill files. So i had to chop off these pins from the socket and soldered them with the pad.
deʃhipu wrote 07/19/2018 at 22:07 point
Wow, that is a pretty good job for manual soldering!
Carl Bugeja wrote 07/21/2018 at 08:45 point
Thanks man 🙂
