Flexible PCB!
A project log for Linear PCB Motor
An Open Source Linear Actuator
carl-bugejaCarl Bugeja 07/09/2018 at 16:560 Comments
I have just ordered a flexible pcb prototype for this project!
The pcb is dual layer and is 0.13mm thick. Although the number of turns have now reduced to 70, the thin dielectric will improve the coupling.
If this works it could open a whole other dimension of applications.
