Was Is Phase Dohanne?
Vapor Phase Soldering / Condensation Soldering
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Our first incursion into homemade reflow soldering will be using a rather uncommon method for hobbyists, that is vapor phase soldering.
This process involves getting a special liquid to its boiling point and lowering the PCB into the vapor.
Perfluoropolyether is heated to 230°C and the vapor tends to stay on the ground because it is heavier than air.
There are a few known difficulties to this process such as the PFPE becoming really nasty stuff at higher temperatures than 300°C (HF) and getting the right temperature profile on the PCBs.
For now, the mechanical stuff and the control circuit is being designed.
