My next project, which I would like to present is AC regulated power supply. This device is very hopeful in electronic developing/repairing. Is better to work with smaller voltages instead of "full power". So I have created controlled device into laboratory.
First I have created a 3D model with components in 1:1 ratio. It is better to know, that everything is matching before assembling.
As a meters, I have chosen the analogs ones. I know, that there is a lot of digitalis, but I did not want to add some additional electronics. Inside the case is ac transformer ESS104. It has a 3 outputs with 4A current. ~250V, ~125V and the regulated 0-250V. Each output has separate connector. The regulated is also connected to EU ~230V plug. ( I do not want to talk about the quality of the plug... .)
There are the final results of device.
Andy
