1
2Hardware Architecture
3Kinematics
The kinematics are written in Python/TKInter, and code can be found on GitHub.
The geometrical drawings were made using the browser-based GeoGebra app.
Trigonometry
Trigonometry based on front view
Trigonometry based on side view
Evolution of the KinematicsElliptical path test Quad kinematics gait test Gait foot pitch test original Gait foot pitch test adjusted -
4Kinematics Class Diagram
5Arduino (OpenCM) Serial and Motor Command Code
This Arduino code allows the OpenCM9.04, together with OpenCM 458 Expansion Board, to receive commands via serial from the Python kinematics code, and in turn send the goal positions and speeds to the AX-12 motors.
LegTestRig_OpenCM.ino
#include <string.h> #define DXL_BUS_SERIAL3 3 //Dynamixel on Serial3(USART3) <- OpenCM 485 EXP int numOfJoints = 22; char cmdBuffer[256]; int bufferCount = 0; Dynamixel Dxl(DXL_BUS_SERIAL3); void setup() { // Initialize the Dynamixel bus // Dynamixel 2.0 Baudrate -> 0: 9600, 1: 57600, 2: 115200, 3: 1Mbps Dxl.begin(3); // Set joint mode for (int i = 0; i < numOfJoints; ++i) Dxl.jointMode(i); // Set compliance Dxl.complianceMargin(254, 1, 1); Dxl.complianceSlope(254, 50, 50); // Home motors Dxl.setPosition(254, 512, 100); // Setup serial SerialUSB.begin(); SerialUSB.attachInterrupt(usbInterrupt); } void loop() { } void usbInterrupt(byte* buffer, byte nCount){ // USB max packet data is 64 bytes, so nCount cannot exceed 64 bytes for(unsigned int i=0; i < nCount; ++i) { char c = (char)buffer[i]; cmdBuffer[bufferCount++] = c; if (c == '\n') { useBuffer(cmdBuffer); buffer[0] = NULL; bufferCount = 0; } } } void useBuffer(char *p) { char * pEnd = p; int x; int count = 0; int id[numOfJoints]; int pos[numOfJoints]; int speed[numOfJoints]; // String format: ID POS SPEED repeated until \n while ( x = strtol(pEnd, &pEnd, 10) ) { id[count] = x; if ( x = strtol(pEnd, &pEnd, 10) ) pos[count] = x; if ( x = strtol(pEnd, &pEnd, 10) ) speed[count] = x; count++; } for (int i = 0; i < count; ++i) { //SerialUSB.println(id[i]); if ( (1 <= id[i]) && (id[i] <= numOfJoints) && (0 <= pos[i]) && (pos[i] <= 1023) && (0 <= speed[i]) && (speed[i] <= 1023) ) { //SerialUSB.print("I got id: "); //SerialUSB.println(id[i]); //SerialUSB.print("I got pos: "); //SerialUSB.println(pos[i]); //SerialUSB.print("I got speed: "); //SerialUSB.println(speed[i]); Dxl.setPosition(id[i], pos[i], speed[i]); //SerialUSB.println("Sent to AX-12!"); } } } /* void useBuffer(char *p) { char * pEnd; int id; int pos; int speed; // String format: ID POS SPEED\n id = strtol(p, &pEnd, 10); pos = strtol(pEnd, &pEnd, 10); speed = strtol(pEnd, NULL, 10); //SerialUSB.print("I got id: "); //SerialUSB.println(id); //SerialUSB.print("I got pos: "); //SerialUSB.println(pos); //SerialUSB.print("I got speed: "); //SerialUSB.println(speed); if ( (1 <= id) && (id <= numOfJoints) && (0 <= pos) && (pos <= 1023) && (0 <= speed) && (speed <= 1023) ) { Dxl.setPosition(id, pos, speed); //SerialUSB.println("Sent to AX-12!"); } } */
Note: A (out-of-date) version of the code, targeting the Arbotix-M, can be found here: LegTestRig.ino.
6Python Timed Operations Thread
Here is an example I figured out, of how to create a Python class to run a function in a separate thread, with a defined time interval, that is pausable/stoppable. It subclasses the Thread class, and uses the help of an Event object to handle the timing functionality. After creating an object of this class, you call its start() method, which invokes the run() method in a separate thread. The pause(), resume() and stop() methods perform the respective actions. The example is a stripped-down version of an input handler, which applies the equations of motion to user inputs, that I created as part of the kinematics code.
Input Handler Example
import threading from time import time import math class InputHandlerExample(threading.Thread): def __init__(self): # Threading/timing vars threading.Thread.__init__(self) self.event = threading.Event() self.dt = 0.05 # 50 ms self.paused = False self.prevT = time() self.currT = time() self.target = 0.0 self.speed = 0.0 # Input vars self.inputNormalised = 0.0 def run(self): while not self.event.isSet(): if not self.paused: self.pollInputs() self.event.wait(self.dt) def pause(self): self.paused = True def resume(self): self.paused = False def stop(self): self.event.set() def pollInputs(self): # Upate current time self.currT = time() # Get user input somehow here, normalise value #self.inputNormalised = getInput() # Update target and speed self.target, self.speed = self.updateMotion( self.inputNormalised, self.target, self.speed) # Make use of the returned target and speed values #useResults(target, speed) # Update previous time self.prevT = self.currT def updateMotion(self, i, target, speed): m = 1.0 u0 = speed # Force minus linear drag inputForceMax = 1000 dragForceCoef = 5 F = inputForceMax*i - dragForceCoef*u0 a = F/m t = self.currT - self.prevT # Zero t if it's too large if t > 0.5: t = 0.0 x0 = target # Equations of motion u = u0 + a*t x = x0 + u0*t + 0.5*a*math.pow(t, 2) return x, u
7Colour Schemes
Default 'Deep blue' colour scheme 'Devastator' colour scheme
'Synthwave' colour scheme
Red/white colour scheme (older model version)
