• Carrier
    Brenda Armour06/01/2018 at 18:16 0 comments
    Carrier is designed to contain Tracker, Forecaster and Replicator is a large chassis. The hardware is the PiFace and Raspberry Pi 1 to control mortars and of course the Chassis itself.
    I am also going to run this on a solar battery pack from Amazon.
  • Replicator
    Brenda Armour06/01/2018 at 18:15 0 comments
    Replicator is designed to capture images and video . The data will be saved to One Drive. The hardware is the Raspberry Pi Zero W and camera. The software is Deep learning object detection with OpenCV.
    Testing on my cat - Jim
  • Forecaster
    Brenda Armour06/01/2018 at 18:13 0 comments
    Forecaster is designed to track current weather conditions at the current location for the Collector. The hardware is a Sensor Tag and a Raspberry Pi 3. Software includes Telegraph (Times -Series Data Collector) and Grafana.  I’m also going to include Darksky forecast for the small area that I will be testing.
  • Tracker
    Brenda Armour06/01/2018 at 18:11 0 comments
    Tracker is designed to trace the route of the Collector with a GPS Tracking device that can stream its coordinates to a near real-time map view. The hardware is a Raspberry Pi 1 with Microstacknode GPS addon board. The coordinates are streamed to Initial State and displayed in real time on a map.
