Dumping the Sample Data
A project log for Sound Machine Sound Swap
Replacing the samples of a cheap sound toy.
owen-truebloodOwen Trueblood 05/14/2018 at 02:151 Comment
The Sound Machine toy is fun for about 1 second - roughly the time it takes to push any of its buttons and hear one of its sounds. After that you'll want to tear it to pieces, which is what I always want anyway. I got mine from a friend, but apparently they can be bought for less than $10 on Amazon.
Upon opening the Sound Machine I found a simple two layer PCB with a smattering of passives, a glob top, and an 8 pin SOIC. It was immediately clear the only hope was the SOIC so I took a closer look and found out from its part number that it's a 25L4006E, a 4 Mb serial flash memory chip. Odds seemed good it stores the samples we are interested in.
I hooked up my Saleae to serial input, output, clock, and chip select. I set the trigger on the CS pin transitioning low, started a capture, pushed a button, and immediately hit pay dirt:
For exactly as long as the sample played there was data being read off of the serial flash chip.
I used the SPI analyzer functionality of the logic analyzer software to get the data and exported it to a CSV. Then I whipped up a quick Python script to convert the data to a WAV audio file as if it were 8 bit PCM. Surprisingly this was enough to start hearing the sounds. Unfortunately it's not just that simple because there is a lot of broadband noise in the signal. For example, here's a spectrogram of the scream sound:
You can see the falling frequencies of the scream itself at the bottom, but all over there is noise. For some of the samples a lot come through, but for most you just hear the noise:
I'm not yet sure where the noise is coming from. Getting rid of it is the next step in this project. After I know how the audio is encoded I can try making my own sample data and loading it onto the serial flash. If you think you know what's up with the noise then please leave a comment, I'd appreciate the help.
Clara Hobbs wrote 05/14/2018 at 14:07 point
Maybe it's compressed somehow?  That could make the data look noisy, anyway.
