Panneau Handicap Normal.jpgThis is the nowaday handicap sign. We wanted to creat new design to make it more adapted or just creat some other humoristic designs.JPEG Image - 10.41 kB - 06/14/2018 at 08:13 |
Blue reflective tape.jpgThis is the tape we used to make the background of our different signs.JPEG Image - 817.69 kB - 06/14/2018 at 08:37 |
White reflective tape.jpgAnd this is the tape we cut for our designs to make a contrast between blue and whiteJPEG Image - 80.85 kB - 06/14/2018 at 08:39 |
AI screen.jpgOn Adobe Illustrator, we created our designs after doing them on paper. We had to learn everything from the basics to handle this.JPEG Image - 111.87 kB - 06/14/2018 at 08:23 |
vidéo silhouette cameo.mp4Here is a example of the Silhouette Cameo in actionMPEG-4 Video - 12.86 MB - 06/14/2018 at 09:20 |
Silhouette Cameo.jpgThis machine is used to cut through the white reflective tape, because if we had used the laser cutter the plastic would have burned. We had some issues while using it because sometimes it didn't cut through it as much as we wanted.JPEG Image - 92.16 kB - 06/14/2018 at 08:45 |
Sanding planks.jpgWe had to cut and to sand the planks we wanted to use to create our five different designs. Like that the reflective tape would stick to those boards.JPEG Image - 399.07 kB - 06/14/2018 at 08:30 |
Final signs.jpgHere is the final result of our project. After the sanding, the sticking,the cutting and the adjustment of everything on the panels.JPEG Image - 171.24 kB - 06/14/2018 at 09:29 |
