Nooelec HackRF Shielding Installation
This is a tutorial on how to install the NooElec HackRF Shielding Kit.
If you own a HackRF, perhaps you too were surprised at the lack of shielding over the RF section. Don't get me wrong, I love this thing, and I'm grateful for the work Michael Ossmann and his crew have done with this. That being said I'm glad Nooelec did the legwork to source a suitable shield for this device. This is a tutorial highlighting the installation of the RF shield for the HackRF One.
Materials Needed:
  1. HackRF One from Great Scott Gadgets.
  2. Nooelec's HackRF Shielding Kit.
  3. ESD safe soldering iron.
  4. No-Clean liquid flux.
  5. Your favorite/best solder.
  6. Your preferred flux cleaner.
  7. Small Plastic Clamp
  • 1 × HackRF One By Great Scott Gadgets
  • 1 × Nooelec HackRF One Shielding Kit
  • Nearly complete!
    Jay Phantom05/15/2018 at 17:48 0 comments
    I just have to add the SnR figures, and waterfall images to compare the device with and without the shield. Those will happen in the next day or so. Thanks all!
  • Tool and Flux selection notes
    Jay Phantom05/15/2018 at 17:16 0 comments
    I used no-clean liquid flux for this build instead of the usual rosin flux, as it's way way easier to clean off of a board with small components, or extra small spaces it can collect in.
    You will also want to find a light clamp to hold the shield down until you tack a couple of the corners.
View all 2 project logs
  • 1
    Prepare Your Board, and Tools.
    I prepped the board by wiping off any dust, and old flux with alcohol, or flux remover on a small cotton cloth, and then used my fiberglass abrasion pen to rough up the areas I was going to solder. After that I washed it again in flux remover to remove any dust from the abrasion process. This provides microscopic etches in the copper that makes for a tighter molecular bond with the solder.
  • 2
    Find a Good Placement for the Shield.
    Before you solder anything, place the shield on the dashed copper lines, and decide how you are going to secure it to the board for soldering.
    Use a light clamp to secure the shielding frame to the PCB. If its too strong it will bend the frame. I used a small plastic clamp with rubber tips you can get at any hardware store.
  • 3
    Solder That Thing!!
    I used a wide, flat-head type soldering iron tip for maximum heat transference. With my rig, 750 degrees F melted the solder fast, and transferred enough heat to the shield body to create a good bond. No more than 4 to 5 seconds of heat per weld. There are some heat sensitive components close to the edge of the shield in a couple of places, be extra careful about heat in those areas, as you may accidentally unseat one of the small resistors or caps in the RF section.
    Starting with the corners, add flux to the tab you're going to solder. Using the wide flat screwdriver shaped tip for my iron, add a bit of solder to the tip, and press between the PCB and the shielding frame. You wanna heat the frame and the copper pad at the same time, so that the solder flows to both. I did it one tab at a time, and let it cool between tabs. I didn't wanna risk heat damage to the sensitive RF section.
    Also, for some of them due to clearance with other board components, I had to solder the tabs from the inside of the frame. See the pics.
View all 4 instructions
Jon wrote 01/01/2023 at 02:02 point
It should be noted that while both these items are still for sale. The most updated rev of the Hack RF already have this implemented. Oh well for me and duh I suppose.
