USB wedge
This is a simple project to interrupt the power of a USB cable
0 comments
0 followers
likes
I plug and unplug USB cables continuously all day and every day. My cable connectors get loose, sockets get worn out, and my concentration gets broken.
This project interrupts the 5V of a USB connection. It sits on the high side of the circuit so that any shared grounds to other test equipment/devices don't leak current.
My first board iteration was simply a PNP (S8550) transistor and a normally closed button that sat inline with two cables.
My second board iteration replaced the S8550 with an AP2171 so that it can switch up to 1A instead of 500mA of current. This board also improves on the original in that a break out pin can be controlled by a microprocessor.
I use these to deploy software to a board via VFAT partition over a USB connection.
First board iteration is available on Tindie: USB micro wedge
Second board iteration is also available on Tindie: USB power micro wedge (5V programmable)
Limited quantities!  While supplies last!
  • outline
    George05/17/2018 at 05:53 0 comments
  • revision 3
    George05/17/2018 at 04:13 0 comments
    Revision 3 of the board came in and I quickly soldered it together and it works.
    I can control the USB port with either a 3.3V/5V MCU!  This should be ideal for automation testing and deploying code.
  • salvaging botched PCBs with bodges
    George05/16/2018 at 01:53 0 comments
    One other thing I didn't notice with the new PCB design was that the USB A connector had its wiring completely reversed in EasyEDA.  I sourced the components and PCB fab through LCSC and JLCPCB, and they were super helpful in refunding my money for the mistake, even though there were already a couple of other mistakes on the board.
    Here we have some bodge wires and some TH components to further test and validate the new design.
  • cost down boo boo
    George05/16/2018 at 01:49 0 comments
    In an attempt to bring the PCB cost down, I spun up a new design, and added support for 3.3V to 5V logic toggling of the AP2171.  Too bad I didn't notice the copper pour was messed up when I uploaded my Gerber to the fab.
View all 4 project logs
