The main enemy for his team is the robot called "Mnotaur". We have no product ideas to overcome its wear, I think we should use ropes or cables to jam the powerful rotating blade.
the other idea to stop the minotaur is:
use mini carts that will have a triangle shape, so you can get stuck in your blade, the only problem is that the blade of the minotaur turns up, and instead of clogging his blade we would be in a shameful situation where our cars come flying in pieces , besides the Rio Robots team had already thought about that kind of thing, you can see that in the lower part of the blade, the minotaur has a piece of metal that covers from side to side the wedges or anything that tries to overturn it, besides It fulfills a very good function to defend itself from our idea of the carts.
