Having troubles with PID control
A project log for Smart Motor Driver for Robotics
This motor driver is able to control a motor using PID by I2C. Taking precise control of a motor have never been so easy.
danny-frDanny FR 06/24/2018 at 04:510 Comments
Tuning the PID with the motor running forward was easy but transition to backwards was a completely whole new pain in the ass. It works now both directions flawlessly, however there is still a bit of overshoot only when moving backwards starting at 0 RPM because it runs forward a little bit and then in the right direction while the system compensates the error.
In the next entry I will explain how I fix the issue and also how to do the PID control like a pro using only simple and standard equations ;)
