Keyboard have 4 layouts switchable with FN button.
- lowercase letters
- uppercase letters
- CTRL + lowercase letter
- CAPS LOCK
of course tweaking is unlimited, you can make own layouts
| LAYOUT | LEDs | Letters |
| 1 - lowercase | A - OFF FN - OFF | ESC, numbers, arrows, Backspace |
| 2- uppercase | A - ON FN - OFF | TAB, symbols, Delete Arrows: UP - Page UP DOWN - Page Down LEFT - Home RIGHT - End After any button press go back to Layout 1 |
| 3- CTRL | A - OFF FN - ON | Letter = CTRL + Letter Numbers = F1 to F10 Return = SHIFT + Return After any button press go back to Layout 1 |
| 4- CAPS LOCK | A - ON FN - ON | Same as mode 2 After any button press stay in Layout 4 |
#include <Keypad.h>
#include "Keyboard.h"
const byte ROWS = 7; //four rows
const byte COLS = 8; //four columns
byte rowPins[ROWS] = {15, 18, 16, 19, 28, 31, 30}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {3, 4, 5, 6, 7, 8, 9, 14}; //connect to the column pinouts of the keypad
//define the cymbols on the buttons of the keypads
char directKeys[ROWS][COLS] = {
{'`', '1', '2', '3', '4', '5', '6', 1},
{KEY_ESC, 'q', 'w', 'e', 'r', 't', 'y', ';'},
{'[', 'a', 's', 'd', 'f', 'g', 'h', 39}, //39 is '
{']', 'z', 'x', 'c', 'v', 'b', 'n', '-'},
{'7', '8', '9', '0', KEY_DOWN_ARROW, KEY_RIGHT_ARROW, KEY_LEFT_ARROW, KEY_UP_ARROW},
{'u', 'i', 'o', 'p', '.', '/', ' ', '='},
{'j', 'k', 'l', KEY_BACKSPACE, 'm', 92, KEY_RETURN, ','}
char shiftKeys[ROWS][COLS] = {
{'~', '!', '@', '#', '$', '%', '^', 1},
{KEY_TAB, 'Q', 'W', 'E', 'R', 'T', 'Y', ';'},
{'{', 'A', 'S', 'D', 'F', 'G', 'H', 34}, //34 is "
{'}', 'Z', 'X', 'C', 'V', 'B', 'N', '_'},
{'&', '*', '(', ')', KEY_PAGE_DOWN, KEY_END, KEY_HOME, KEY_PAGE_UP},
{'U', 'I', 'O', 'P', '>', '?', ' ', '+'},
{'J', 'K', 'L', KEY_DELETE, 'M', 92, KEY_RETURN, ','}
char fnKeys[ROWS][COLS] = {
{'`', KEY_F1, KEY_F2, KEY_F3, KEY_F4, KEY_F5, KEY_F6, 1},
{KEY_F7, KEY_F8, KEY_F9, KEY_F10, KEY_DOWN_ARROW, KEY_RIGHT_ARROW, KEY_LEFT_ARROW, KEY_UP_ARROW},
char capsKeys[ROWS][COLS] = {
{KEY_ESC, 'Q', 'W', 'E', 'R', 'T', 'Y', ';'},
{'[', 'A', 'S', 'D', 'F', 'G', 'H', 39}, //39 is '
{']', 'Z', 'X', 'C', 'V', 'B', 'N', '-'},
{'U', 'I', 'O', 'P', '.', '/', ' ', '='},
{'J', 'K', 'L', KEY_BACKSPACE, 'M', 92, KEY_INSERT, ','}
// Create 3 new key layouts
Keypad directLayout( makeKeymap(directKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) );
Keypad shiftLayout( makeKeymap(shiftKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) );
Keypad fnLayout( makeKeymap(fnKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) );
Keypad capsLayout( makeKeymap(capsKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) );
byte Layout = 0;
char Key = 0;
#define ledaA 27
#define ledFn 17
void setup() {
Keyboard.begin();
pinMode(ledaA, OUTPUT);
pinMode(ledFn, OUTPUT);
digitalWrite(ledaA, LOW);
digitalWrite(ledFn, LOW);
directLayout.begin( makeKeymap(directKeys) );
shiftLayout.begin( makeKeymap(shiftKeys) );
fnLayout.begin( makeKeymap(fnKeys) );
capsLayout.begin( makeKeymap(capsKeys) );
void loop() {
switch (Layout) {
case 0:
Key = directLayout.getKey();
break;
case 1:
digitalWrite(ledaA, HIGH);
Key = shiftLayout.getKey();
if (Key >= 2) {
Layout = 0;
break;
case 2:
digitalWrite(ledFn, HIGH);
Key = fnLayout.getKey();
if (Key >= 2) {
Layout = 0; //
if (Key == KEY_RETURN)
Keyboard.press(KEY_LEFT_SHIFT);
if ((Key >= 'a') && (Key <= 'z'))
Keyboard.press(KEY_LEFT_CTRL);
break;
case 3:
Key = capsLayout.getKey();
break;
default:
Layout = 0;
break;
if (Key == 1)
Layout++;
Key = 0;
delay(300); //
if (Key) {
// Keyboard.press(ctrlKey);
Keyboard.press(Key);
delay(100);
Keyboard.releaseAll();
bobricius
