I want to make, and document plans for, a collaborative desktop multi-axis rotary wire electrical discharge machine.  I'm using Will Langford's desktop wire EDM design in the link below as a starting point, so much of the hard work looks like it's done.  Before I start working on a design, I would like to get members' input for recommended design changes in order to increase build volume, add machine axes, use more off-the-shelf components, and to reduce the cost and time to build.
Link to Will Langford's Desktop Wire EDM: https://web.archive.org/web/20220121234105/http://fab.cba.mit.edu/classes/865.15/people/will.langford/11_final/index.html
Will Langford is awesome: https://web.archive.org/web/20211107164911/http://www.willlangford.me/
Related links:
5-Axis Desktop CNC Milling Machine:
Pocketnc.com
AI meets CNC: https://techcrunch.com/2018/06/07/cloudnc/
