Detailed log Below ->>
Ackermann steering, Autonomous self-driving Nitro RC Car, ROS based.
Portable Network Graphics (PNG) - 80.28 kB - 05/20/2018 at 12:58 |
pi-bottom-plate.stlsource: https://www.thingiverse.com/thing:1998099 credit: ancapaaronStandard Tesselated Geometry - 41.98 kB - 05/20/2018 at 12:20 |
pi-top-plate.stlsource: https://www.thingiverse.com/thing:1998099 credit: ancapaaronStandard Tesselated Geometry - 38.95 kB - 05/20/2018 at 12:20 |
xv11_lidar.stlsource: https://www.thingiverse.com/thing:1707495 credit: deadsyStandard Tesselated Geometry - 325.50 kB - 05/20/2018 at 12:18 |
HolderPlate-Top.STLsource: https://www.thingiverse.com/thing:1464811 credit: zankuroStandard Tesselated Geometry - 212.78 kB - 05/20/2018 at 12:17 |
Mechanical
Getting the RC Car ready to go after ~10 years, engine compression seems to be good, carburetor is completely cleaned. Found out the car didn’t start because of a small pin between the crankshaft and the backplate, when pulling the cord, it rotated only the shaft at the backplate. Instead of ordering a new spring/pull mechanism (didn’t have the patience) just put some Teflon tape between the crankshaft and the small pin, it worked perfectly.
Next, designing the parts, I’ve separated this to three major units:
Rear Unit: Webcam, Lights(Later).
Center Unit: Power Regulators (5V and 3.3V), Power Distribution Board, RC Receiver.
Front Unit: Battery, XV11 Lidar, Orange Pi.
Rear Unit: 1x Logitech C170
Center Unit:
Main power supply – LIPO 7.4 2200mah, several components at this design works at 5V/3.3, will use two different regulators:
1xLM2596 – 5V 3A Buck converter
1xAMS1117 – 3.3V 800mA Buck converter
Wrote a ROS package in python for processing the image from the Logitech C170 (Code available on GitHub). In most example codes available online it's easier to detect the lane by filtering out the lane colors(white, yellow), here i did it in a narrow street so i didn't have many colors to filter out.
Based on the great tutorial of Galen Ballew:
https://medium.com/@galen.ballew/opencv-lanedetection-419361364fc0
I had to do many modification so it will work without filtering the yellow and white colors, I've used the following steps:
1. Convert to HSV
2. Filter out background colors.
3. Calculating Sobel magnitude.
4. Flood Fill.
5. Split to left and right image.
5. Manually find contours.
6. Draw a line for the left and right edge.
I got the following result:
Running Yolo object detection, with VOC weights on the image(offline), we got the following result -
Next time:
I had to record some bagfiles to start working on the lane tracking, auto steering of the car. To make things easier i thought of connecting the Flysky RC to a simple python code and by toggle the switch on the remote start and pause the rosbag record process. Connecting the Flysky RC to OrangePi sounds like an easy task, had some issues with sampling the PWM signal from the remote at frequency high enough to determine the switch state(This can be done easly on Raspberry Pi using pigpio), if you have some ADC to I2C you can do it easly, something like ADS1115, or just playing with RC circuit.
I didn't have enough time to spend on it, so a simple Arduino Nano was perfect for this task. Routing the SWD on Flysky to CH6 on the reciever and connecting it to PIN 6 on the Arduino.
The python code for reading values for Arduino and starting the record sometimes doesn't end cleanly(will be fixed later), need to run this on the bags -
rosbag reindex *.bag.active
rosbag fix *.bag.active repaired.bag
Software
echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" >ros-latest.list
sudo cp ros-latest.list /etc/apt/sources.list.d/
sudo apt-key adv --keyserver hkp://ha.pool.sks-keyservers.net:80 --recv-key 421C365BD9FF1F717815A3895523BAEEB01FA116
sudo apt-get update
sudo apt-get install ros-kinetic-ros-base
sudo rosdep init
rosdep update
Congratulations, you have ROS kinetic running on your Orange PI. Add some of the basic ROS packages, such as Hector SLAM, and the drivers to XV11, based on this tutorial: http://meetjanez.splet.arnes.si/2015/08/22/neato-xv-11-to-ros-slam/
Got the XV11 lidar work on the Nitro RC, example of the Laserscan:
Next weeks:
Next, designing the parts, I’ve separated this to three major units: Rear Unit: Webcam, Lights(Later). Center Unit: Power Regulators (5V and 3.3V), Power Distribution Board, RC Receiver. Front Unit: Battery, XV11 Lidar, Orange Pi.
Center Unit: Main power supply – LIPO 7.4 2200mah, several components at this design works at 5V/3.3, will use two different regulators: 1xLM2596 – 5V 3A Buck converter 1xAMS1117 – 3.3V 800mA Buck converter
Front Unit: 1x Orange Pi Lite(Allwinner H3) 1x XV11 Neato Lidar 1x STM32F103C8
Software
echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" >ros-latest.list sudo cp ros-latest.list /etc/apt/sources.list.d/ sudo apt-key adv --keyserver hkp://ha.pool.sks-keyservers.net:80 --recv-key 421C365BD9FF1F717815A3895523BAEEB01FA116 sudo apt-get update sudo apt-get install ros-kinetic-ros-base sudo rosdep init rosdep update
Next weeks:
